A Comprehensive Framework for Saturation Theorem Proving - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a framework for formal refutational completeness proofs of abstract provers that implement saturation calculi, such as ordered resolution or superposition. The framework relies on modular extensions of lifted redundancy criteria. It allows us to extend redundancy criteria so that they cover subsumption, and also to model entire prover architectures in such a way that the static refutational completeness of a calculus immediately implies the dynamic refutational completeness of a prover implementing the calculus, for instance within an Otter or DISCOUNT loop. Our framework is mechanized in Isabelle/HOL.
satur_paper.pdf (487.33 Ko) Télécharger le fichier
hal-03106208 , version 1 (11-01-2021)
Uwe Waldmann, Sophie Tourret, Simon Robillard, Jasmin Blanchette. A Comprehensive Framework for Saturation Theorem Proving. IJCAR 2020 (Part I) International Joint Conference on Automated Reasoning, Jun 2020, Paris, France. pp.316-334, ⟨10.1007/978-3-030-51074-9_18⟩. ⟨hal-03106208⟩
68 Consultations
102 Téléchargements
