A reconstruction of Edward Sang's table of sines in degrees (K44,1879) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
This document gives a reconstruction of Edward Sang (1805-1890)'s table of sines scaled by 200/pi. This is Sang's volume K44, and it was used in the construction of his table of circular segments (table K45).
sang1879sines-degrees-K44-doc.pdf (1.11 Mo) Télécharger le fichier
hal-03106598 , version 1 (11-01-2021)
  • HAL Id : hal-03106598 , version 1
Denis Roegel. A reconstruction of Edward Sang's table of sines in degrees (K44,1879). [Research Report] LORIA. 2020. ⟨hal-03106598⟩
32 Consultations
1215 Téléchargements
