Type-generic lambdas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
For the lambda expressions that were introduced in N2633, we propose the addition of auto parameters that can be completed by the arguments (in a function call) or by the parameter types of target function pointer (in a conversion).
Mots clés
N2634.pdf (402.89 Ko) Télécharger le fichier
hal-03106919 , version 3 (12-01-2021)
hal-03106919 , version 4 (10-06-2021)
hal-03106919 , version 1 (14-06-2021)
hal-03106919 , version 2 (02-02-2022)
hal-03106919 , version 5 (06-10-2022)
  • HAL Id : hal-03106919 , version 3
Jens Gustedt. Type-generic lambdas: proposal for C23. [Research Report] N2634, ISO JCT1/SC22/WG14. 2021, pp.10. ⟨hal-03106919v3⟩
Collections
IMRB UPEC
238 Consultations
201 Téléchargements
