Lvalue closures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
Lvalue closures
For the lambda expressions that were introduced in N2633, we propose the addition of lvalue captures that can read and modify objects of surrounding scopes
Mots clés
N2635.pdf (371.44 Ko) Télécharger le fichier
hal-03106930 , version 2 (12-01-2021)
hal-03106930 , version 3 (10-06-2021)
hal-03106930 , version 1 (14-06-2021)
Paternité
  • HAL Id : hal-03106930 , version 2
Jens Gustedt. Lvalue closures: proposal for C23. [Research Report] N2635, ISO JCT1/SC22/WG14. 2021, pp.8. ⟨hal-03106930v2⟩
134 Consultations
123 Téléchargements
