TgAP2IX-5 is a key transcriptional regulator of the asexual cell cycle division in Toxoplasma gondii - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Communications Année : 2021
Apicomplexan parasites have evolved efficient and distinctive strategies for intracellular replication where the timing of emergence of the daughter cells (budding) is a decisive element. However, the molecular mechanisms that provide the proper timing of parasite budding remain unknown. Using Toxoplasma gondii as a model Apicomplexan, we identified a master regulator that controls the timing of the budding process. We show that an ApiAP2 transcription factor, TgAP2IX-5, controls cell cycle events downstream of centrosome duplication. TgAP2IX-5 binds to the promoter of hundreds of genes and controls the activation of the budding-specific cell cycle expression program. TgAP2IX-5 regulates the expression of specific transcription factors that are necessary for the completion of the budding cycle. Moreover, TgAP2IX-5 acts as a limiting factor that ensures that asexual proliferation continues by promoting the inhibition of the differentiation pathway. Therefore, TgAP2IX-5 is a master regulator that controls both cell cycle and developmental pathways.
s41467-020-20216-x.pdf (1.77 Mo) Télécharger le fichier
hal-03107529 , version 1 (24-11-2020)
hal-03107529 , version 2 (12-01-2021)
Paternité
Asma S. Khelifa, Cecilia Guillen Sanchez, Kevin M. Lesage, Ludovic Huot, Thomas Mouveaux, et al.. TgAP2IX-5 is a key transcriptional regulator of the asexual cell cycle division in Toxoplasma gondii. Nature Communications, 2021, 12, pp.116. ⟨10.1038/s41467-020-20216-x⟩. ⟨hal-03107529v2⟩
206 Consultations
120 Téléchargements
