Tone mapping high dynamic 3D scenes with global lightness coherency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Graphics Année : 2020
We propose a new approach for real-time Tone Mapping Operator dedicated to High Dynamic Range rendering of interactive 3D scenes. The proposed method considers the whole scene lighting in order to preserve the global coherency. This is the major contribution of our method. Indeed, most of existing Tone Mapping Operators only consider the image rendered by the camera at the current frame and simulate the Human Visual System accommodation to bright and dark luminance. Consequently, after an adaptation time, the lighting design of the 3D scene is lost. For example, two rooms with a high contrast (one dark and one bright) can be perceived with the same luminance level after adaptation. To cope with this coherency issue, we adapt an existing Tone Mapping Operator that combines (1) a global Tone Mapping Operator which takes into account the High Dynamic Range of the whole scene and (2) a viewport frame based Tone Mapping Operator that enhances the image contrast. Thus, we preserve the global lighting coherency and enhance the contrast for each rendered image. Furthermore, we present a subjective evaluation that shows that our method provides a better user experience than previous methods in the case of visualization on Head-Mounted Display.
3D_TMO__C_G___HAL_.pdf (18.65 Mo) Télécharger le fichier
hal-03192365 , version 1 (08-04-2021)
Ific Goudé, Jérémy Lacoche, Rémi Cozot. Tone mapping high dynamic 3D scenes with global lightness coherency. Computers and Graphics, 2020, 91, pp.243-251. ⟨10.1016/j.cag.2020.08.004⟩. ⟨hal-03192365⟩
83 Consultations
78 Téléchargements
