The initial-boundary value problem for the Lifshitz-Slyozov equation with non-smooth rates at the boundary - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinearity Année : 2021
We prove existence and uniqueness of solutions to the initialboundary value problem for the Lifshitz-Slyozov equation (a nonlinear transport equation on the half-line), focusing on the case of kinetic rates with unbounded derivative at the origin. Our theory covers in particular those cases with rates behaving as power laws at the origin, for which an inflow behavior is expected and a boundary condition describing nucleation phenomena needs to be imposed. The method we introduce here to prove existence is based on a formulation in terms of characteristics, with a careful analysis on the behavior near the singular boundary. As a byproduct we provide a general theory for linear continuity equations on a half-line with transport fields that degenerate at the boundary. We also address both the maximality and the uniqueness of inflow solutions to the Lifshitz-Slyozov model, exploiting monotonicity properties of the associated transport equation.
revision_v8_submitted.pdf (451.7 Ko) Télécharger le fichier
hal-03109431 , version 1 (13-01-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
Juan Calvo, Erwan Hingant, Romain Yvinec. The initial-boundary value problem for the Lifshitz-Slyozov equation with non-smooth rates at the boundary. Nonlinearity, 2021, 34 (04), pp.1975-2017. ⟨10.1088/1361-6544/abd3f3⟩. ⟨hal-03109431⟩
86 Consultations
86 Téléchargements
