Preprints, Working Papers, ...
hp -Version discontinuous Galerkin methods on essentially arbitrarily-shaped elements
Abstract : We extend the applicability of the popular interior-penalty discontinuous Galerkin (dG) method discretizing advection-diffusion-reaction problems to meshes comprising extremely general, essentially arbitrarily-shaped element shapes. In particular, our analysis allows for curved element shapes, without the use of non-linear elemental maps. The feasibility of the method relies on the definition of a suitable choice of the discontinuity penalization, which turns out to be explicitly dependent on the particular element shape, but essentially independent on small shape variations. This is achieved upon proving extensions of classical trace inverse estimate to arbitrary element shapes. A further new H1 − L2-type inverse estimate on essentially arbitrary element shapes enables the proof of inf-sup stability of the method in a streamline diffusion-like norm. These inverse estimates may be of independent interest. A priori error bounds for the resulting method are given under very mild structural assumptions restricting the magnitude of the local curvature of element boundaries. Numerical experiments are also presented, indicating the practicality of the proposed approach.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-03109470
Contributor : Zhaonan Dong <>
Submitted on : Monday, April 19, 2021 - 6:33:38 PM
Last modification on : Tuesday, May 11, 2021 - 3:32:58 AM
File
DG-EASE_Revision_3.pdf
Identifiers
  • HAL Id : hal-03109470, version 2
  • ARXIV : 1906.01715
Collections
Citation
Andrea Cangiani, Zhaonan Dong, Emmanuil Georgoulis. hp -Version discontinuous Galerkin methods on essentially arbitrarily-shaped elements. 2021. ⟨hal-03109470v2⟩
Share
Metrics
Record views
30
Files downloads
112
