Efficient computation of Riemann-Roch spaces for plane curves with ordinary singularities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applicable Algebra in Engineering, Communication and Computing Année : 2022
We revisit the seminal Brill-Noether algorithm for plane curves with ordinary singularities. Our new approach takes advantage of fast algorithms for polynomials and structured matrices. We design a new probabilistic algorithm of type Las Vegas that computes a Riemann-Roch space in expected sub-quadratic time.
rrordinary.pdf (596 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-03110135 , version 1 (14-01-2021)
Simon Abelard, Alain Couvreur, Grégoire Lecerf. Efficient computation of Riemann-Roch spaces for plane curves with ordinary singularities. Applicable Algebra in Engineering, Communication and Computing, 2022, ⟨10.1007/s00200-022-00588-x⟩. ⟨hal-03110135⟩
237 Consultations
523 Téléchargements
