Global implicit function theorems and the online Expectation-Maximisation algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Australian and New Zealand Journal of Statistics Année : 2022
The expectation-maximisation (EM) algorithm is an important tool for statistical computation. Due to the changing nature of data, online and mini-batch variants of EM and EM-like algorithms have become increasingly popular. The consistency of the estimator sequences that are produced by these EM variants often rely on an assumption regarding the continuous differentiability of a parameter update function. In many cases, the parameter update function is often not in closed form and may only be defined implicitly, which makes the verification of the continuous differentiability property difficult. We demonstrate how a global implicit function theorem can be used to verify such properties in the cases of finite mixtures of distributions in the exponential family and more generally when the component specific distribution admits a data augmentation scheme in the exponential family. We demonstrate the use of such a theorem in the case of mixtures of beta distributions, gamma distributions, fully-visible Boltzmann machines and Student distributions. Via numerical simulations, we provide empirical evidence towards the consistency of the online EM algorithm parameter estimates in such cases.
oemrev14hal.pdf (23.4 Mo) Télécharger le fichier
hal-03110213 , version 1 (14-01-2021)
hal-03110213 , version 2 (12-11-2021)
Hien Duy Nguyen, Florence Forbes. Global implicit function theorems and the online Expectation-Maximisation algorithm. Australian and New Zealand Journal of Statistics, 2022, 64 (2), pp.255-281. ⟨10.1111/anzs.12356⟩. ⟨hal-03110213v2⟩
158 Consultations
127 Téléchargements
