Memory-Augmented Reinforcement Learning for Image-Goal Navigation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
In this work, we address the problem of image-goal navigation in the context of visually-realistic 3D environments. This task involves navigating to a location indicated by a target image in a previously unseen environment. Earlier attempts, including RL-based and SLAM-based approaches, have either shown poor generalization performance, or are heavily-reliant on pose/depth sensors. We present a novel method that leverages a cross-episode memory to learn to navigate. We first train a state-embedding network in a self-supervised fashion, and then use it to embed previously-visited states into a memory. In order to avoid overfitting, we propose to use data augmentation on the RGB input during training. We validate our approach through extensive evaluations, showing that our data-augmented memory-based model establishes a new state of the art on the image-goal navigation task in the challenging Gibson dataset. We obtain this competitive performance from RGB input only, without access to additional sensors such as position or depth.
arxiv_final.pdf (2.3 Mo) Télécharger le fichier
hal-03110875 , version 1 (14-01-2021)
hal-03110875 , version 2 (02-03-2022)
hal-03110875 , version 3 (12-09-2022)
Lina Mezghani, Sainbayar Sukhbaatar, Thibaut Lavril, Oleksandr Maksymets, Dhruv Batra, et al.. Memory-Augmented Reinforcement Learning for Image-Goal Navigation. 2021. ⟨hal-03110875v1⟩
295 Consultations
325 Téléchargements
