Multiparameter Persistence Images for Topological Machine Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mathieu Carriere
Andrew J Blumberg
  • Fonction : Auteur
  • PersonId : 1088681
In the last decade, there has been increasing interest in topological data analysis, a new methodology for using geometric structures in data for inference and learning. A central theme in the area is the idea of persistence, which in its most basic form studies how measures of shape change as a scale parameter varies. There are now a number of frameworks that support statistics and machine learning in this context. However, in many applications there are several different parameters one might wish to vary: for example, scale and density. In contrast to the one-parameter setting, techniques for applying statistics and machine learning in the setting of multiparameter persistence are not well understood due to the lack of a concise representation of the results. We introduce a new descriptor for multiparameter persistence, which we call the Multiparameter Persistence Image, that is suitable for machine learning and statistical frameworks, is robust to perturbations in the data, has finer resolution than existing descriptors based on slicing, and can be efficiently computed on data sets of realistic size. Moreover, we demonstrate its efficacy by comparing its performance to other multiparameter descriptors on several classification tasks.
NeurIPS-2020-multiparameter-persistence-image-for-topological-machine-learning-Paper.pdf (964.96 Ko) Télécharger le fichier
hal-03112442 , version 1 (16-01-2021)
Paternité
  • HAL Id : hal-03112442 , version 1
Mathieu Carriere, Andrew J Blumberg. Multiparameter Persistence Images for Topological Machine Learning. NeurIPS 2020 - 33rd Conference on Neural Information Processing Systems, Dec 2020, Vancouver / Virtuel, Canada. ⟨hal-03112442⟩
203 Consultations
371 Téléchargements
