ETSI SmartM2M Technical Report 103714: Study for oneM2M Discovery and Query use cases and requirements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2021
oneM2M has currently native discovery capabilities that work properly only if the search is related to specific known sources of information (e.g. searching for the values of a known set of containers) or if the discovery is well scoped and designed (e.g. the lights in a house). When oneM2M is used to discover wide sets of data or unknown sets of data, the functionality is typically integrated by ad hoc applications that are expanding the oneM2M functionality. This means that this core function may be implemented with different flavours and this is not optimal for interworking and interoperability. The objective of the present document [i.1] in conjunction with three other ones [i.2], [i.3] and [i.4] is the study and development of semantic Discovery and Query capabilities for oneM2M and its contribution to the oneM2M standard. The goal is to enable an easy and efficient discovery of information and a proper interworking with external source/consumers of information (e.g. a distributed data base in a smart city or in a firm), or to directly search information in the oneM2M system for big data purposes.
tr_103714v010101p.pdf (635.99 Ko) Télécharger le fichier
hal-03115482 , version 1 (19-01-2021)
  • HAL Id : hal-03115482 , version 1
Luigi Liquori, Enrico Scarrone, Marie-Agnès Peraldi-Frati, Andrea Cimmino, Raúl García Castro, et al.. ETSI SmartM2M Technical Report 103714: Study for oneM2M Discovery and Query use cases and requirements. 2021. ⟨hal-03115482⟩
161 Consultations
158 Téléchargements
