No Free Lunch - Characterizing the Performance of 6TiSCH When Using Different Physical Layers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Sensors Année : 2020
Mina Rady
  • Fonction : Auteur
  • PersonId : 1062727
Quentin Lampin
Dominique Barthel
  • Fonction : Auteur
  • PersonId : 957196
Low-power wireless applications require different trade off points between latency, reliability ,data rate and power consumption. Given such a set of constraints, which physical layer should I beusing? We study this question in the context of 6TiSCH,a state-of-the-art recently standardized protocol stack developed for harsh industrial applications. Specifically,we augment OpenWSN, the reference 6TiSCHopen-source implementation,to support one of three physical layers from the IEEE802.15.4g standard FSK 868 MHz which offers long range, OFDM 868 MHz which offers high data rate,and O-QPSK 2.4GHz which offers more balanced performance. We run the resulting firmware on the42-mote Open Testbed deployed in an office environment, once for each physical layer. Performance results show that, indeed, no physical layer outperforms the other for all metrics. This article argues for combining the physical layers, rather than choosing one,in a generalized 6TiSCH architecture in which technology-agile radio chips (of which there are now many) are driven by a protocol stack which c hooses the most appropriate physical layer on a frame-by-frame basis.
rady20free.pdf (2.4 Mo) Télécharger le fichier
hal-03115505 , version 1 (19-01-2021)
Mina Rady, Quentin Lampin, Dominique Barthel, Thomas Watteyne. No Free Lunch - Characterizing the Performance of 6TiSCH When Using Different Physical Layers. Sensors, In press, ⟨10.3390/s20174989⟩. ⟨hal-03115505⟩
Collections
INRIA INRIA2
73 Consultations
101 Téléchargements
