Split analysis and fronthaul dimensioning in 5G C-RAN to guarantee ultra low latency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The use of Ethernet packet-switched networks for the fronthaul links with a Cloud-based Radio Access Network (C-RAN) architecture are nowadays considered. The high capacity and low latency fronthaul (FH) links requirement in the C-RAN architecture can be reduced by a flexible functional split of baseband processing between remote radio heads (RRHs) and Baseband units (BBUs). These will allow leveraging statistical multiplexing gains, infrastructure reuse and cost reduction. However, in order to satisfy latency requirements, most of the studies advocate the use of lower fronthaul split options like the eCPRI (evolved Common Public Radio Interface) Iu split, requiring huge fronthaul link capacity. In this paper, we propose an alternative uplink physical split, denoted II U . The objective is to reduce capacity requirements on the fronthaul while meeting latency constraints. As a future work, the proposed split will be evaluted and analyzed for both fast and slow fading channel situations.
Fichier non déposé
hal-03116035 , version 1 (20-01-2021)
Hadjer Touati, Hind Castel-Taleb, Badii Jouaber, Sarah Akbarzadeh. Split analysis and fronthaul dimensioning in 5G C-RAN to guarantee ultra low latency. CCNC 2020: IEEE 17th Annual Consumer Communications Networking Conference, Jan 2020, Las Vegas, United States. pp.1-4, ⟨10.1109/CCNC46108.2020.9045398⟩. ⟨hal-03116035⟩
30 Consultations
0 Téléchargements
