Deep Learning-based Transmitter identification on the physical layer
An essential part of most wireless communications systems is the identification of a transmitter by a receiver. Being able to identify a transmitter at the physical layer gives context to the communication itself, but is also an important building block for more advanced techniques such as physical layer security. It can also be used to reduce overhead
main.pdf (735.19 Ko)
Télécharger le fichier
Data/data_type.dat (95 B)
Data/graph_cross_test.dat (178 B)
Data/graph_data_type.dat (95 B)
Data/graph_multi_training_ability.dat (104 B)
Data/graph_multi_train_chair.dat (119 B)
Data/graph_oversampling.dat (1.18 Ko)
Data/graph_sync_loss.dat (288 B)
Data/graph_time_offset.dat (679 B)
Data/graph_training_ability.dat (77 B)
Data/multi_training_ability.dat (104 B)
Data/noise.dat (141 B)
Data/random.dat (141 B)
Data/static.dat (141 B)
figures/Archi.pdf (131.09 Ko)
figures/ArchiBig.png (22.73 Ko)
figures/cortexlab.pdf (17.34 Ko)
figures/cortexlab.svg (25.71 Ko)
figures/Emitter_trigger.png (15.14 Ko)
figures/frame.png (277.64 Ko)
figures/model.drawio (2.65 Ko)
figures/model.pdf (25.46 Ko)
figures/model.png (15.37 Ko)
figures/model_id.pdf (35.66 Ko)
figures/model_id.svg (214.84 Ko)
figures/overall_structure.pdf (16.23 Ko)
figures/overall_structure.svg (22.46 Ko)
figures/reception.png (23.43 Ko)
figures/rx.pdf (27.92 Ko)
figures/rx.svg (34.7 Ko)
figures/turtle_in_cortexlab.jpg (170.53 Ko)
figures/tx.pdf (12.54 Ko)
figures/tx.svg (16.87 Ko)
figures/tx_data.pdf (30.32 Ko)
figures/tx_data.svg (22.33 Ko)
main.log (69.14 Ko)
main.out (1.72 Ko)
main.synctex.gz (172.31 Ko)
Paper_TxID.pdf (711.93 Ko)
Paper_TxID_2col.pdf (725.16 Ko)
