A short proof on the rate of convergence of the empirical measure for the Wasserstein distance
We provide a short proof that the Wasserstein distance between the empirical measure of a n-sample and the estimated measure is of order n^−1/d , if the measure has a lower and upper bounded density on the d-dimensional flat torus.
