A short proof on the rate of convergence of the empirical measure for the Wasserstein distance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We provide a short proof that the Wasserstein distance between the empirical measure of a n-sample and the estimated measure is of order n^−1/d , if the measure has a lower and upper bounded density on the d-dimensional flat torus.
note.pdf (281.15 Ko) Télécharger le fichier
hal-03117283 , version 1 (21-01-2021)
  • HAL Id : hal-03117283 , version 1
Vincent Divol. A short proof on the rate of convergence of the empirical measure for the Wasserstein distance. 2021. ⟨hal-03117283⟩
73 Consultations
274 Téléchargements
