Private types in Higher Order Logic Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We report on ongoing work on introducing a mechanism for private types in a higher-order logic programming language such as λ Prolog.
privtypes.pdf (123.18 Ko) Télécharger le fichier
hal-03117762 , version 1 (21-01-2021)
  • HAL Id : hal-03117762 , version 1
Marco Maggesi, Enrico Tassi. Private types in Higher Order Logic Programming. TEASE-LP 2020 - Workshop on Trends, Extensions, Applications and Semantics of Logic Programming, May 2020, Virtual Event, France. ⟨hal-03117762⟩
55 Consultations
111 Téléchargements
