Homotopy perturbation technique for improving solutions of large quadratic eigenvalue problems: Application to friction-induced vibration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mechanical Systems and Signal Processing Année : 2021
This paper puts forward a projection technique for accurately calculating solutions of large Quadratic Eigenvalue Problem. The aim here is to stabilize the complex eigensolutions whilst reducing residual errors, especially when considering significant damping contribution or asymmetric stiffness matrices. Hence, more confident results can be obtained in the frequency band of interest. To achieve this, high order modes, calculated using the homotopy perturbation technique, are introduced in the projection step of the classical method. This numerical proposal is a generalization of the classical projection, based only on normal modes of the associated undamped problem. To evaluate the efficiency of the suggested method, a finite element application dedicated to a friction-induced vibration problem is investigated.
Article_final.pdf (2.04 Mo) Télécharger le fichier
hal-03118102 , version 2 (21-01-2021)
hal-03118102 , version 1 (30-09-2021)
Jérémy Sadet, Franck Massa, Thierry Tison, Isabelle Turpin, Bertrand Lallemand, et al.. Homotopy perturbation technique for improving solutions of large quadratic eigenvalue problems: Application to friction-induced vibration. Mechanical Systems and Signal Processing, 2021, 153, pp.107492. ⟨10.1016/j.ymssp.2020.107492⟩. ⟨hal-03118102v2⟩
151 Consultations
164 Téléchargements
