Probabilistic Schedulability Analysis for Precedence Constrained Tasks on Partitioned Multi-core
The design of cyber-physical systems (CPSs) is facing the explosion of new functionalities requiring increased computation capacities and, thus, the introduction of multi-core processors. Moreover, some functionalities may impose precedence constraints between the programs implementing these new functionalities. While important effort has been dedicated to the scheduling of precedence constraints tasks on multi-core processors, existing work considers either partitioned scheduling for a single precedence graph defining precedence constraints between tasks, or global scheduling policies.In this paper, we consider partitioned scheduling for multiple precedence graphs defining precedence constraints between tasks. The variability of execution times and of communication times is described by probability distributions. We propose a new response time analysis over-performing existing ILP-based results. Thanks to its scalability, our solution is extendable to a probabilistic version and we validate it on a PX4 drone autopilot. Beside this autopilot for our experiments, we implemented a probabilistic extension of a multi-core processor simulator, SimSo. A priority assignment heuristic allowing parallel executions is also proposed. Thanks to its adaptation to partitioned scheduling, our heuristic has better performances than existing solutions and its performances are, also, compared against a genetic-based heuristic.
