Case-Based Reasoning, Analogy, and Interpolation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2020
This chapter presents several types of reasoning based on analogy and similarity. Case-based reasoning, presented in Section 2, consists in searching a case (where a case represents a problem-solving episode) similar to the problem to be solved and to adapt it to solve this problem. Section 3 is devoted to analogical reasoning and to recent developments based on analogical proportion. Interpolative reasoning, presented in Section 4 in the formal setting of fuzzy set representations, is another form of similarity-based reasoning.
volume-1-chapitre-10-Springer.pdf (277.83 Ko) Télécharger le fichier
hal-03119305 , version 1 (23-01-2021)
Béatrice Fuchs, Jean Lieber, Laurent Miclet, Alain Mille, Amedeo Napoli, et al.. Case-Based Reasoning, Analogy, and Interpolation. Pierre Marquis; Odile Papini; Henri Prade. A Guided Tour of Artificial Intelligence Research, Volume I: Knowledge Representation, Reasoning and Learning, Springer International Publishing, pp.307-339, 2020, A Guided Tour of Artificial Intelligence Research, 978-3-030-06163-0. ⟨10.1007/978-3-030-06164-7_10⟩. ⟨hal-03119305⟩
145 Consultations
523 Téléchargements
