Freezer: A Specialized NVM Backup Controller for Intermittently-Powered Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems Année : 2021
The explosion of IoT and wearable devices determined a rising attention towards energy harvesting as source for powering these systems. In this context, many applications cannot afford the presence of a battery because of size, weight and cost issues. Therefore, due to the intermittent nature of ambient energy sources, these systems must be able to save and restore their state, in order to guarantee progress across power interruptions. In this work, we propose a specialized backup/restore controller that dynamically tracks the memory accesses during the execution of the program. The controller then commits the changes to a snapshot in a Non-Volatile Memory (NVM) when a power failure is detected. Our approach does not require complex hybrid memories and can be implemented with standard components. Results on a set of benchmarks show an average 8× reduction in backup size. Thanks to our dedicated controller, the backup time is further reduced by more than 100×, with an area and power overhead of only 0.4% and 0.8%, respectively, w.r.t. a low-end IoT node.
Freezer_TCAD_Revised_Version.pdf (4.07 Mo) Télécharger le fichier
hal-03119369 , version 1 (25-01-2021)
Davide Pala, Ivan Miro-Panades, Olivier Sentieys. Freezer: A Specialized NVM Backup Controller for Intermittently-Powered Systems. IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, 2021, 40 (8), pp.1559-1572. ⟨10.1109/TCAD.2020.3025063⟩. ⟨hal-03119369⟩
194 Consultations
243 Téléchargements
