Design Space Exploration of Heterogeneous-Accelerator SoCs with Hyperparameter Optimization
Modern SoC systems consist of general-purpose processor cores augmented with large numbers of specialized accelerators. Building such systems requires a design flow allowing the design space to be explored at the system level with an appropriate strategy. In this paper, we describe a methodology allowing to explore the design space of power-performance heterogeneous SoCs by combining an architecture simulator (gem5-Aladdin) and a hyperparameter
optimization method (Hyperopt). This methodology allows different types of parallelism with loop unrolling strategies and memory coherency interfaces to be swept. The flow has been applied to a convolutional neural network algorithm. We show that the most energy efficient architecture achieves a 2x to 4x improvement in energy-delay-product compared to an architecture without parallelism. Furthermore, the obtained solution is more efficient than commonly implemented architectures (Systolic, 2D-mapping, and Tiling). We also applied the methodology to find the optimal architecture including its coherency interface for a complex SoC made up of six accelerated-workloads.We show that a hybrid interface appears to be the most efficient; it reaches 22% and 12% improvement in energy-delay-product compared to just only using non-coherent and only LLC-coherent models, respectively.
Architectures Matérielles [cs.AR]
