DEEP SETS FOR GENERALIZATION IN RL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tristan Karch
Cédric Colas
Pierre-Yves Oudeyer
This paper investigates the idea of encoding object-centered representations in the design of the reward function and policy architectures of a language-guided reinforcement learning agent. This is done using a combination of object-wise permutation invariant networks inspired from Deep Sets and gated-attention mechanisms. In a 2D procedurally-generated world where agents targeting goals in natural language navigate and interact with objects, we show that these architectures demonstrate strong generalization capacities to out-of-distribution goals. We study the generalization to varying numbers of objects at test time and further extend the object-centered architectures to goals involving relational reasoning.
2003.09443.pdf (6.22 Mo) Télécharger le fichier
hal-03120669 , version 1 (26-01-2021)
Tristan Karch, Cédric Colas, Laetitia Teodorescu, Clément Moulin-Frier, Pierre-Yves Oudeyer. DEEP SETS FOR GENERALIZATION IN RL. Beyond Tabula Rasa in Reinforcement Learning: agents that remember adapt and generalize, Workshop at ICLR, Apr 2021, Addis Ababa, Ethiopia. ⟨hal-03120669⟩
Collections
ENSTA INRIA INRIA2
52 Consultations
137 Téléchargements
