FCA and Knowledge Discovery (Tutorial) - Archive ouverte HAL Access content directly
Conference Papers Year : 2020
(1)
1
Amedeo Napoli
In this tutorial we will introduce and discuss how FCA and two main extensions, namely Pattern Structures and Relational Concept Analysis (RCA), can be used for knowledge discovery purposes, especially in pattern and rule mining, in data and knowledge processing, data analysis, and classification. Indeed, FCA is aimed at building a concept lattice starting from a binary table where objects are in rows and attributes in columns. But FCA can deal with more complex data. Pattern Structures allow to consider objects with descriptions based on numbers, intervals, sequences, trees and general graphs. RCA was introduced for taking into account relational data and especially relations between objects. These two extensions rely on adapted FCA algorithms and can be efficiently used in real-world applications for knowledge discovery, e.g. text mining and ontology engineering, information retrieval and recommendation, analysis of sequences based on stability, semantic web and classification of Linked Open Data, biclustering, and functional dependencies.
iccs20-tutorial-200918sp.pdf (172.89 Ko) Télécharger le fichier
Dates and versions
hal-03122350 , version 1 (26-01-2021)
Identifiers
Cite
Amedeo Napoli. FCA and Knowledge Discovery (Tutorial). ICCS 2020 - 25th International Conference on Conceptual Structures, Sep 2020, Bolzano/ Virtual, Italy. ⟨10.1007/978-3-030-57855-8⟩. ⟨hal-03122350⟩
64 View
140 Download
Share
