Taking advantage of pathogen diversity and immune priming to minimize disease prevalence in host mixtures: a model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue (Article De Synthèse) Phytopathology Année : 2021
Host mixtures are a promising method for agroecological plant disease control. Plant immunity is key to the success of host mixtures against polymorphic pathogen populations. This immunity results from priming-induced cross-protection, whereby plants able to resist infection by specific pathogen genotypes become more resistant to other pathogen genotypes. Strikingly, this phenomenon was absent from mathematical models aiming at designing host mixtures. We developed a model to specifically explore how priming affects the coexistence of two pathogen genotypes in host mixtures composed of two host genotypes and how it affects disease prevalence. The main effect of priming is to reduce the coexistence region in the parameter space (due to the cross-protection) and to generate a singular mixture of resistant and susceptible hosts corresponding to the maximal reduction disease prevalence (in absence of priming, a resistant pure stand is optimal). The epidemiological advantage of host mixtures over a resistant pure stand thus appears as a direct consequence of immune priming. We also showed that there is indirect cross-protection between host genotypes in a mixture. Moreover, the optimal mix prevents the emergence of a resistance-breaking pathogen genotype. Our results highlight the importance of considering immune priming to design optimal and sustainable host mixtures.
Taking_advantage_of_pathogen_diversity__Revision_.pdf (264.67 Ko) Télécharger le fichier
hal-03124229 , version 1 (28-01-2021)
Pauline Clin, Frédéric Grognard, Ludovic Mailleret, Florence Val, Didier Andrivon, et al.. Taking advantage of pathogen diversity and immune priming to minimize disease prevalence in host mixtures: a model. Phytopathology, 2021, 111 (7), pp.1219-1227. ⟨10.1094/PHYTO-09-20-0429-R⟩. ⟨hal-03124229⟩
245 Consultations
105 Téléchargements
