Convergence of a fully discrete and energy-dissipating finite-volume scheme for aggregation-diffusion equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2020
José A. Carrillo
  • Fonction : Auteur
  • PersonId : 833062
Hideki Murakawa
  • Fonction : Auteur
  • PersonId : 1089759
We study an implicit finite-volume scheme for non-linear, non-local aggregation-diffusion equations which exhibit a gradient-flow structure, recently introduced in [3]. Crucially, this scheme keeps the dissipation property of an associated fully discrete energy, and does so unconditionally with respect to the time step. Our main contribution in this work is to show the convergence of the method under suitable assumptions on the diffusion functions and potentials involved.
2002.10821.pdf (674.69 Ko) Télécharger le fichier
hal-03125839 , version 1 (29-01-2021)
Rafael Bailo, José A. Carrillo, Hideki Murakawa, Markus Schmidtchen. Convergence of a fully discrete and energy-dissipating finite-volume scheme for aggregation-diffusion equations. Mathematical Models and Methods in Applied Sciences, 2020, 30 (13), pp.2487-2522. ⟨10.1142/S0218202520500487⟩. ⟨hal-03125839⟩
76 Consultations
58 Téléchargements
