Queries with Arithmetic on Incomplete Databases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The standard notion of query answering over incomplete database is that of certain answers, guaranteeing correctness regardless of how incomplete data is interpreted. In majority of real-life databases,relations have numerical columns and queries use arithmetic and comparisons. Even though the notion of certain answers still applies,we explain that it becomes much more problematic in situations when missing data occurs in numerical columns. We propose a new general framework that allows us to assign a measure of certainty to query answers. We test it in the agnostic scenario where we do not have prior information about values of numerical attributes, similarly to the predominant approach in handling incomplete data which assumes that each null can be interpreted as an arbitrary value of the domain. The key technical challenge is the lack of a uniform distribution over the entire domain of numerical attributes, such as real numbers. We overcome this by associating the measure of certainty with the asymptotic behaviorof volumes of some subsets of the Euclidean space. We show that this measure is well-defined, and describe approaches to computing and approximating it. While it can be computationally hard, or result in an irrational number, even for simple constraints, we produce polynomial-time randomized approximation schemes with multiplicative guarantees for conjunctive queries, and with additive guarantees for arbitrary first-order queries. We also describe a set of experimental results to confirm the feasibility of this approach.
qai.pdf (828.65 Ko) Télécharger le fichier
hal-03127717 , version 1 (01-02-2021)
Marco Console, Matthias Hofer, Leonid Libkin. Queries with Arithmetic on Incomplete Databases. SIGMOD/PODS 2020 : International Conference on Management of Data, Jun 2020, Portland / Virtual, United States. pp.179-189, ⟨10.1145/3375395.3387666⟩. ⟨hal-03127717⟩
36 Consultations
196 Téléchargements
