Conference papers
Learn to improve: A novel deep reinforcement learning approach for beyond 5G network slicing
Anouar Rkhami 1 Yassine Hadjadj-Aoul 1 Abdelkader Outtagarts 2
1 DIONYSOS - Dependability Interoperability and perfOrmance aNalYsiS Of networkS
Inria Rennes – Bretagne Atlantique , IRISA-D2 - RÉSEAUX, TÉLÉCOMMUNICATION ET SERVICES
Abstract : Network slicing remains one of the key technologies in 5G and beyond 5G networks (B5G). By leveraging SDN and NVF techniques, it enables the coexistence of several heterogeneous virtual networks (VNs) on top of the same physical infrastructure. Despite the advantages it brings to network operators, network slicing raises a major challenge: Resource allocation of VNs, also known as the virtual network embedding problem (VNEP). VNEP is known to be an NP-Hard problem. Several heuristics, meta-heuristics and Deep Reinforcement Learning (DRL) based solutions were proposed in the literature to solve it. Regarding the first two categories, they can provide a solution for large scale problems within a reasonable time, but the solution is usually suboptimal, which leads to an inefficient utilization of the resources and increases the cost of the allocation process. For DRL-based approaches and due to the explorationexploitation dilemma, the solution can be infeasible. To overcome these issues, we combine, in this work, deep reinforcement learning and relational graph convolutional neural networks in order to automatically learn how to improve the quality of VNEP heuristics. Simulation results show the effectiveness of our approach. Starting with an initial solution given by the heuristics our approach can find an amelioration, with an improvement in the order of 35%.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03510121
Contributor : Yassine Hadjadj Aoul Connect in order to contact the contributor
Submitted on : Tuesday, January 4, 2022 - 2:10:05 PM
Last modification on : Friday, January 21, 2022 - 3:23:20 AM
File
RGCN_DRL_PAPER.pdf
Identifiers
Citation
Anouar Rkhami, Yassine Hadjadj-Aoul, Abdelkader Outtagarts. Learn to improve: A novel deep reinforcement learning approach for beyond 5G network slicing. CCNC 2021 - IEEE 18th Annual Consumer Communications & Networking Conference, Jan 2021, Las Vegas, United States. pp.1-6, ⟨10.1109/CCNC49032.2021.9369463⟩. ⟨hal-03510121⟩
Share
Metrics
Les métriques sont temporairement indisponibles
