A first approach for a passenger-centered behavior on driverless vehicles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Driverless shuttles are becoming one of the most promising applications of automated vehicle technologies in the short term. For a real system deployment, passenger's acceptance on the shuttle performance will play a key role. This paper presents a passenger-centered control algorithm design for increasing passenger's ride quality. Controllers with different performance but properly following the reference are developed for lane-level autonomous navigation. The whole solution has been implemented and tested in a real vehicle, using a roundabout as use-case scenario, providing encouraging results.
Paper_NavControl_2.pdf (2.61 Mo) Télécharger le fichier
hal-03130132 , version 1 (03-02-2021)
  • HAL Id : hal-03130132 , version 1
David González, Francisco Navas, Imane Mahtout, Vicente Milanés. A first approach for a passenger-centered behavior on driverless vehicles. MED'2020 - 28th Mediterranean Conference on Control and Automation, Sep 2020, Saint-Raphaël / Virtual, France. ⟨hal-03130132⟩
Collections
INRIA INRIA2
20 Consultations
72 Téléchargements
