A sub-Riemannian model of the visual cortex with frequency and phase - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Neuroscience Année : 2020
In this paper we present a novel model of the primary visual cortex (V1) based on orientation, frequency and phase selective behavior of the V1 simple cells. We start from the first level mechanisms of visual perception: receptive profiles. The model interprets V1 as a fiber bundle over the 2-dimensional retinal plane by introducing orientation, frequency and phase as intrinsic variables. Each receptive profile on the fiber is mathematically interpreted as a rotated, frequency modulated and phase shifted Gabor function. We start from the Gabor function and show that it induces in a natural way the model geometry and the associated horizontal connectivity modeling the neural connectivity patterns in V1. We provide an image enhancement algorithm employing the model framework. The algorithm is capable of exploiting not only orientation but also frequency and phase information existing intrinsically in a 2-dimensional input image. We provide the experimental results corresponding to the enhancement algorithm.
J_MathNeuroSci_13_Sep_19_ArXiV_version.pdf (1.25 Mo) Télécharger le fichier
hal-02319510 , version 1 (18-10-2019)
Emre Baspinar, Alessandro Sarti, Giovanna Citti. A sub-Riemannian model of the visual cortex with frequency and phase. Journal of Mathematical Neuroscience, 2020, 10 (11), ⟨10.1186/s13408-020-00089-6⟩. ⟨hal-02319510⟩
128 Consultations
38 Téléchargements
