Global dynamics of the chemostat with overflow metabolism - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Biology Année : 2021
We analyze the asymptotic behavior of the periodically forced light limited Droop model, representing microalgae growth. We consider general monotone growth and uptake rate functions. Based on a conservation principle, we reduce the model to a limiting planar periodic system of differential equations. The reduced system generates a monotone dynamical system. Combining this fact with results on periodic Kolmogorov equations, we find conditions such that any solution of the reduced model approaches to a positive periodic solution. Under these conditions, if the reduced system admits only one positive periodic solution, using the theory of asymptotically periodic semiflows, we extend the results on the limiting system to the original model. Finally, based on results of monotone sub-homogeneous dynamical systems, we give conditions to determine the uniqueness of positive periodic solutions
preprint_overflow.pdf (466.04 Ko) Télécharger le fichier
hal-03130387 , version 1 (03-02-2021)
Paternité
Carlos Martínez, Jean-Luc Gouzé. Global dynamics of the chemostat with overflow metabolism. Journal of Mathematical Biology, 2021, 82 (3), ⟨10.1007/s00285-021-01566-6⟩. ⟨hal-03130387⟩
111 Consultations
286 Téléchargements
