C-language floating-point proofs layered with VST and Flocq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Formalized Reasoning Année : 2020
Andrew W. Appel
  • Fonction : Auteur
  • PersonId : 925802
We demonstrate tools and methods for proofs about the correctness and numerical accuracy of C programs. The tools are foundational, in that they are connected to formal semantic specifications of the C operational semantics and of the IEEE 754 floating-point format. Theools are modular, in that the reasoning about C programming can be done quite separately from the reasoning about numerical correctness and numerical accuracy. The tools are general, in that they accommodate amost the entire C language (with pointer data structures, function pointers, control flow, etc.) and applied mathematics (reasoned about in a general-purpose logic and proof assistant with substantial libraries for mathematical reasoning). We demonstrate on a simple Newton's-method square root function.
paper_v2.pdf (460.34 Ko) Télécharger le fichier
hal-03130704 , version 1 (03-02-2021)
hal-03130704 , version 2 (08-03-2021)
Paternité
Andrew W. Appel, Yves Bertot. C-language floating-point proofs layered with VST and Flocq. Journal of Formalized Reasoning, 2020, 13 (1), pp.1-16. ⟨10.6092/issn.1972-5787/11442⟩. ⟨hal-03130704v2⟩
124 Consultations
229 Téléchargements
