On finite/fixed-time stability analysis based on sup-and sub-homogeneous extensions
Fixed-time and finite-time stabilities of non-linear systems are investigated using the introduced notions of sub-and sup-homogeneity. These concepts allow the systems to be analyzed using the homogeneity, even if they do not admit homogeneous approximations. Finite-time and fixed-time stability properties can be established using homogeneity degree of sub-and sup-homogeneous extensions.
Automatique
