On finite/fixed-time stability analysis based on sup-and sub-homogeneous extensions - Archive ouverte HAL Access content directly
Journal Articles Systems and Control Letters Year : 2021
Fixed-time and finite-time stabilities of non-linear systems are investigated using the introduced notions of sub-and sup-homogeneity. These concepts allow the systems to be analyzed using the homogeneity, even if they do not admit homogeneous approximations. Finite-time and fixed-time stability properties can be established using homogeneity degree of sub-and sup-homogeneous extensions.
On_finite_fixed_time_stability_analysis_based_on_sup__and_sub_homogeneous_extensions-BRAIDIZ.pdf (521.39 Ko) Télécharger le fichier
Dates and versions
hal-03131583 , version 1 (04-02-2021)
hal-03131583 , version 2 (09-02-2021)
Identifiers
Cite
Youness Braidiz, Andrey Polyakov, Denis Efimov, Wilfrid Perruquetti. On finite/fixed-time stability analysis based on sup-and sub-homogeneous extensions. Systems and Control Letters, In press, 150, ⟨10.1016/j.sysconle.2021.104893⟩. ⟨hal-03131583v2⟩
121 View
182 Download
Share
