Log-Normalization Constant Estimation using the Ensemble Kalman-Bucy Filter with Application to High-Dimensional Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
In this article we consider the estimation of the log-normalization constant associated to a class of continuous-time filtering models. In particular, we consider ensemble Kalman-Bucy filter based estimates based upon several nonlinear Kalman-Bucy diffusions. Based upon new conditional bias results for the mean of the afore-mentioned methods, we analyze the empirical log-scale normalization constants in terms of their $\mathbb{L}_n-$errors and conditional bias. Depending on the type of nonlinear Kalman-Bucy diffusion, we show that these are of order $(\sqrt{t/N}) + t/N$ or $1/\sqrt{N}$ ($\mathbb{L}_n-$errors) and of order $[t+\sqrt{t}]/N$ or $1/N$ (conditional bias), where $t$ is the time horizon and $N$ is the ensemble size. Finally, we use these results for online static parameter estimation for above filtering models and implement the methodology for both linear and nonlinear models.
hal-03131613 , version 1 (04-02-2021)
Dan Crisan, Pierre del Moral, Ajay Jasra, Hamza Ruzayqat. Log-Normalization Constant Estimation using the Ensemble Kalman-Bucy Filter with Application to High-Dimensional Models. 2021. ⟨hal-03131613⟩
35 Consultations
0 Téléchargements
