Online Spectrogram Inversion for Low-Latency Audio Source Separation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Signal Processing Letters Année : 2020
Paul Magron
Tuomas Virtanen
  • Fonction : Auteur
  • PersonId : 1113848
Audio source separation is usually achieved by estimating the short-time Fourier transform (STFT) magnitude of each source, and then applying a spectrogram inversion algorithm to retrieve time-domain signals. In particular, the multiple input spectrogram inversion (MISI) algorithm has been exploited successfully in several recent works. However, this algorithm suffers from two drawbacks, which we address in this paper. First, it has originally been introduced in a heuristic fashion: we propose here a rigorous optimization framework in which MISI is derived, thus proving the convergence of this algorithm. Besides, while MISI operates offline, we propose here an online version of MISI called oMISI, which is suitable for low-latency source separation, an important requirement for e.g., hearing aids applications. oMISI also allows one to use alternative phase initialization schemes exploiting the temporal structure of audio signals. Experiments conducted on a speech separation task show that oMISI performs as well as its offline counterpart, thus demonstrating its potential for real-time source separation.
Online_MISI.pdf (525.72 Ko) Télécharger le fichier
hal-03132170 , version 1 (11-10-2021)
Paul Magron, Tuomas Virtanen. Online Spectrogram Inversion for Low-Latency Audio Source Separation. IEEE Signal Processing Letters, 2020, 27, pp.306-310. ⟨10.1109/LSP.2020.2970310⟩. ⟨hal-03132170⟩
192 Consultations
72 Téléchargements
