Model-based trace variant analysis of event logs
The comparison of trace variants of business processes opens the door for a fine-grained analysis of the
distinctive features inherent in the executions of a process in an organization. The current approaches for
trace variant analysis do not consider the situation where a process model is present, and therefore, it
can guide the derivation of the trace variants by considering high-level structures present in the process model.
In this paper we propose a fresh alternative to trace variant analysis, which proposes a generalized notion of
trace variant that incorporates concurrency and iteration. This way, the analyst may be relieved from analysing trace variants
that are essentially the same, if these aspects are disregarded. We propose a general algorithm for model based trace variant analysis
which is grounded in encoding the problem into SAT, and a family of heuristic alternatives including a very light sampling technique
that represents a good trade-off between quality of the trace variants identified, and the complexity of the analysis. All the techniques of the
paper are implemented in two open-source tools, and experiments with publicly available benchmarks are reported.
