Improvements of Algebraic Attacks for Solving the Rank Decoding and MinRank Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we show how to significantly improve algebraic techniques for solving the MinRank problem, which is ubiquitous in multivariate and rank metric code based cryptography. In the case of the structured MinRank instances arising in the latter, we build upon a recent breakthrough [11] showing that algebraic attacks outperform the combinatorial ones that were considered state of the art up until now. Through a slight modification of this approach, we completely avoid Gr¨obner bases computations for certain parameters and are left only with solving linear systems. This does not only substantially improve the complexity, but also gives a convincing argument as to why algebraic techniques work in this case. When used against the second round NIST-PQC candidates ROLLO-I-128/192/256, our new attack has bit complexity respectively 71, 87, and 151, to be compared to 117, 144, and 197 as obtained in [11]. The linear systems arise from the nullity of the maximal minors of a certain matrix associated to the algebraic modeling. We also use a similar approach to improve the algebraic MinRank solvers for the usual MinRank problem. When applied against the second round NIST-PQC candidates GeMSS and Rainbow, our attack has a complexity that is very close to or even slightly better than those of the best known attacks so far. Note that these latter attacks did not rely on MinRank techniques since the MinRank approach used to give complexities that were far away from classical security levels.
articlev2.pdf (516.01 Ko) Télécharger le fichier
hal-03133479 , version 1 (06-02-2021)
Magali Bardet, Maxime Bros, Daniel Cabarcas, Philippe Gaborit, Ray Perlner, et al.. Improvements of Algebraic Attacks for Solving the Rank Decoding and MinRank Problems. ASIACRYPT 2020 - 26th International Conference on the Theory and Application of Cryptology and Information Security, Dec 2020, Daejeon / Virtual, South Korea. pp.507--536, ⟨10.1007/978-3-030-64837-4_17⟩. ⟨hal-03133479⟩
753 Consultations
680 Téléchargements
