Programming at the edge of synchrony - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Synchronization primitives for fault-tolerant distributed systems that ensure an effective and efficient cooperation among processes are an important challenge in the programming languages community. We present a new programming abstraction, ReSync, for implementing benign and Byzantine fault-tolerant protocols. ReSync has a new round structure that offers a simple abstraction for group communication, like it is customary in synchronous systems, but also allows messages to be received one by one, like in the asynchronous systems. This extension allows implementing network and algorithm-specific policies for the message reception, which is not possible in classic round models. The execution of ReSync programs is based on a new generic round switch protocol that generalizes the famous theoretical result of ?. We evaluate experimentally the performance of ReSync's execution platform, by comparing consensus implementations in ReSync with LibPaxos3, etcd, and Bft-SMaRt, three consensus libraries tolerant to benign, resp. byzantine faults.
oopsla20F.pdf (949.76 Ko) Télécharger le fichier
hal-03134314 , version 1 (08-02-2021)
Cezara Dragoi, Josef Widder, Damien Zufferey. Programming at the edge of synchrony. SPLASH 2020 - ACM SIGPLAN conference on Systems, Programming, Languages, and Applications: Software for Humanity, Oct 2020, Chicago / Virtual, United States. ⟨10.1145/3428281⟩. ⟨hal-03134314⟩
50 Consultations
82 Téléchargements
