Lightweight AEAD and Hashing using the Sparkle Permutation Family - Archive ouverte HAL Access content directly
Journal Articles IACR Transactions on Symmetric Cryptology Year : 2020
We introduce the Sparkle family of permutations operating on 256, 384 and 512 bits. These are combined with the Beetle mode to construct a family of authenticated ciphers, Schwaemm, with security levels ranging from 120 to 250 bits. We also use them to build new sponge-based hash functions, Esch256 and Esch384. Our permutations are among those with the lowest footprint in software, without sacrificing throughput. These properties are allowed by our use of an ARX component (the Alzette S-box) as well as a carefully chosen number of rounds. The corresponding analysis is enabled by the long trail strategy which gives us the tools we need to efficiently bound the probability of all the differential and linear trails for an arbitrary number of rounds. We also present a new application of this approach where the only trails considered are those mapping the rate to the outer part of the internal state, such trails being the only relevant trails for instance in a differential collision attack. To further decrease the number of rounds without compromising security, we modify the message injection in the classical sponge construction to break the alignment between the rate and our S-box layer.
Not file
Dates and versions
hal-03135807 , version 1 (09-02-2021)
Identifiers
Cite
Christof Beierle, Alex Biryukov, Luan Cardoso dos Santos, Johann Grossschädl, Léo Perrin, et al.. Lightweight AEAD and Hashing using the Sparkle Permutation Family. IACR Transactions on Symmetric Cryptology, 2020, Special Issue on Designs for the NIST Lightweight Standardisation Process, 2020 (S1), pp.208--261. ⟨10.13154/tosc.v2020.iS1.208-261⟩. ⟨hal-03135807⟩
Collections
INRIA INRIA2
30 View
0 Download
Share
