$L_2$ and BIBO stability of systems with variable delays - Archive ouverte HAL Access content directly
Journal Articles Systems and Control Letters Year : 2020
This paper considers $L_2$ and BIBO stability and stabilization issues for systems with time-varying delays which can be of retarded or neutral type. An important role is played by a nominal system with fixed delays which are close to the time-varying ones. Under stability or stabilizability conditions of this nominal system, sufficient conditions are given in order to ensure similar properties for the system with time-varying delays.
variabledelay_final2.pdf (284.48 Ko) Télécharger le fichier
Dates and versions
hal-03136388 , version 1 (09-02-2021)
Identifiers
  • HAL Id : hal-03136388 , version 1
Cite
Catherine Bonnet, Jonathan R Partington. $L_2$ and BIBO stability of systems with variable delays. Systems and Control Letters, 2020. ⟨hal-03136388⟩
47 View
141 Download
Share
