Spook: Sponge-Based Leakage-Resistant Authenticated Encryption with a Masked Tweakable Block Cipher - Archive ouverte HAL Access content directly
Journal Articles IACR Transactions on Symmetric Cryptology Year : 2020
Chun Guo
  • Function : Author
This paper defines Spook: a sponge-based authenticated encryption with associated data algorithm. It is primarily designed to provide security against side-channel attacks at a low energy cost. For this purpose, Spook is mixing a leakageresistant mode of operation with bitslice ciphers enabling efficient and low latency implementations. The leakage-resistant mode of operation leverages a re-keying function to prevent differential side-channel analysis, a duplex sponge construction to efficiently process the data, and a tag verification based on a Tweakable Block Cipher (TBC) providing strong data integrity guarantees in the presence of leakages. The underlying bitslice ciphers are optimized for the masking countermeasures against side-channel attacks. Spook is an efficient single-pass algorithm. It ensures state-ofthe-art black box security with several prominent features: (i) nonce misuse-resilience, (ii) beyond-birthday security with respect to the TBC block size, and (iii) multiuser security at minimum cost with a public tweak. Besides the specifications and design rationale, we provide first software and hardware implementation results of (unprotected) Spook which confirm the limited overheads that the use of two primitives sharing internal components imply. We also show that the integrity of Spook with leakage, so far analyzed with unbounded leakages for the duplex sponge and a strongly protected TBC modeled as leak free, can be proven with a much weaker unpredictability assumption for the TBC. We finally discuss external cryptanalysis results and tweaks to improve both the security margins and efficiency of Spook.
8623-Article Text-5221-2-10-20200622.pdf (1.24 Mo) Télécharger le fichier
Dates and versions
hal-03136493 , version 1 (09-02-2021)
Attribution - CC BY 4.0
Identifiers
Cite
Davide Bellizia, Francesco Berti, Olivier Bronchain, Gaëtan Cassiers, Sébastien Duval, et al.. Spook: Sponge-Based Leakage-Resistant Authenticated Encryption with a Masked Tweakable Block Cipher. IACR Transactions on Symmetric Cryptology, 2020, Special Issue on Designs for the NIST Lightweight Standardisation Process, 2020 (S1), pp.295--349. ⟨10.13154/tosc.v2020.iS1.295-349⟩. ⟨hal-03136493⟩
Collections
INRIA INRIA2
150 View
189 Download
Share
