LIO*: Low Level Information Flow Control in F* - Archive ouverte HAL Access content directly
Other Publications Year : 2020
Jean-Joseph Marty
  • Function : Author
  • PersonId : 1051354
Lucas Franceschino
  • Function : Author
  • PersonId : 1090610
Jean-Pierre Talpin
We present Labeled Input Output in F* (LIO*), a verified framework that enforces information flow control (IFC) policies developed in F* and automatically extracted to C. Inspired by LIO, we encapsulated IFC policies into effects, but using F* we derived efficient, low level, and provably correct code. Concretely, runtime checks are lifted to static proof obligations, the developed code is automatically extracted to C and proved non-interferent using metaprogramming. We benchmarked our framework on three clients and observed up to 54% speedup when IFC runtime checks are proved statically. Our framework is designed to aid development of embedded devices where both enforcement of security policies and low level efficient code is critical.
2004.12885.pdf (727.32 Ko) Télécharger le fichier
Dates and versions
hal-03137132 , version 1 (10-02-2021)
Identifiers
Cite
Jean-Joseph Marty, Lucas Franceschino, Jean-Pierre Talpin, Niki Vazou. LIO*: Low Level Information Flow Control in F*. 2020. ⟨hal-03137132⟩
32 View
49 Download
Share
