Optimized Lifting Scheme Based on a Dynamical Fully Connected Network for Image Coding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Wavelet decompositions based on lifting schemes have been widely used in image coding. Generally, the efficiency of such compression methods strongly depends on the design of the lifting operators, namely the prediction and update filters. To improve their performance, we propose in this paper to optimize these filters by resorting to two learning strategies. In the first one, classical Fully Connected Networks (FCNs) are exploited to perform the prediction and update. In the second approach, we develop an adaptive learning method that takes into account the input image, yielding a dynamical model of FCN. Experimental results, carried out on the standard Challenge Learned Image Compression (CLIC) dataset, show the benefits that can be drawn from the proposed approaches compared to conventional ones.
ICIP_2020.pdf (624.65 Ko) Télécharger le fichier
hal-03139684 , version 1 (12-02-2021)
Tassnim Dardouri, Mounir Kaaniche, Amel Benazza-Benyahia, Jean-Christophe Pesquet. Optimized Lifting Scheme Based on a Dynamical Fully Connected Network for Image Coding. ICIP 2020 - The 27th IEEE International Conference on Image Processing, Oct 2020, Virtual, United Arab Emirates. ⟨10.1109/ICIP40778.2020.9191292⟩. ⟨hal-03139684⟩
92 Consultations
131 Téléchargements
