HNPE: Leveraging Global Parameters for Neural Posterior Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Inferring the parameters of a stochastic model based on experimental observations is central to the scientific method. A particularly challenging setting is when the model is strongly indeterminate, i.e. when distinct sets of parameters yield identical observations. This arises in many practical situations, such as when inferring the distance and power of a radio source (is the source close and weak or far and strong?) or when estimating the amplifier gain and underlying brain activity of an electrophysiological experiment. In this work, we present hierarchical neural posterior estimation (HNPE), a novel method for cracking such indeterminacy by exploiting additional information conveyed by an auxiliary set of observations sharing global parameters. Our method extends recent developments in simulation-based inference (SBI) based on normalizing flows to Bayesian hierarchical models. We validate quantitatively our proposal on a motivating example amenable to analytical solutions and then apply it to invert a well known non-linear model from computational neuroscience.
neurips_2021.pdf (1.83 Mo) Télécharger le fichier
hal-03139916 , version 1 (12-02-2021)
hal-03139916 , version 2 (06-10-2021)
hal-03139916 , version 3 (10-11-2021)
  • HAL Id : hal-03139916 , version 3
Pedro Luiz Coelho Rodrigues, Thomas Moreau, Gilles Louppe, Alexandre Gramfort. HNPE: Leveraging Global Parameters for Neural Posterior Estimation. NeurIPS 2021, Dec 2021, Sydney (Online), Australia. ⟨hal-03139916v3⟩
209 Consultations
118 Téléchargements
