Weak Solutions for a System Modeling the Movement of a Piston in a Viscous Compressible Gas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Fluid Mechanics Année : 2020
We first study the global-in-time existence of strong solutions to a one-dimensional system modeling the movement of a piston in a viscous compressible gas. Moreover, we prove the asymptotic stability of the solution toward a chosen constant state (in the sense that we can impose the final position of the piston, the final densities being fixed by the conservation of mass and the choice of the final position) thanks to a constant force acting in the equation of the point mass whose expression depends explicitly of the chosen final position. The norm of the solution in the function space of the initial data decays exponentially toward this constant state. Then, we prove the existence of weak solutions to this system for initial velocity in the energy state and for the initial density with bounded total variation. The weak solution is unique and also decay exponentially toward the chosen constant state thanks to the same constant force acting on the point mass. We use the result of existence of strong solutions to prove the existence of weak solutions, whereas the result on exponential decay of weak solution is independent of the one for the strong solutions.
Fichier non déposé
hal-03140597 , version 1 (13-02-2021)
Julien Lequeurre. Weak Solutions for a System Modeling the Movement of a Piston in a Viscous Compressible Gas. Journal of Mathematical Fluid Mechanics, 2020, 22 (3), pp.40. ⟨10.1007/s00021-020-0481-y⟩. ⟨hal-03140597⟩
33 Consultations
0 Téléchargements
