Approximate tensorization of the relative entropy for noncommuting conditional expectations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales Henri Poincaré Année : 2022
In this paper, we derive a new generalisation of the strong subadditivity of the entropy to the setting of general conditional expectations onto arbitrary finite-dimensional von Neumann algebras. The latter inequality, which we call approximate tensorization of the relative entropy, can be expressed as a lower bound for the sum of relative entropies between a given density and its respective projections onto two intersecting von Neumann algebras in terms of the relative entropy between the same density and its projection onto an algebra in the intersection, up to multiplicative and additive constants. In particular, our inequality reduces to the so-called quasi-factorization of the entropy for commuting algebras, which is a key step in modern proofs of the logarithmic Sobolev inequality for classical lattice spin systems. We also provide estimates on the constants in terms of conditions of clustering of correlations in the setting of quantum lattice spin systems. Along the way, we show the equivalence between conditional expectations arising from Petz recovery maps and those of general Davies semigroups.
hal-03140651 , version 1 (13-02-2021)
Ivan Bardet, Angela Capel, Cambyse Rouzé. Approximate tensorization of the relative entropy for noncommuting conditional expectations. Annales Henri Poincaré, 2022, 23 (1), pp.101-140. ⟨10.1007/s00023-021-01088-3⟩. ⟨hal-03140651⟩
Collections
INRIA INRIA2
70 Consultations
0 Téléchargements
