Controllability to trajectories of a Ladyzhenskaya model for a viscous incompressible fluid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mathématique Année : 2021
We consider the controllability of a viscous incompressible fluid modeled by the Navier-Stokes systemwith a nonlinear viscosity. To prove the controllability to trajectories, we linearize around a trajectory andthe corresponding linear system includes a nonlocal spatial term. Our main result is a Carleman estimatefor the adjoint of this linear system. This estimate yields in a standard way the null controllability of thelinear system and the local controllability to trajectories. Our method to obtain the Carleman estimate iscompletely general and can be adapted to other parabolic systems when a Carleman estimate is available.
GuerreroTakahashi.pdf (272.24 Ko) Télécharger le fichier
hal-03140709 , version 1 (13-02-2021)
  • HAL Id : hal-03140709 , version 1
Sergio Guerrero, Takéo Takahashi. Controllability to trajectories of a Ladyzhenskaya model for a viscous incompressible fluid. Comptes Rendus. Mathématique, 2021. ⟨hal-03140709⟩
95 Consultations
89 Téléchargements
